Got up this morning to go to work and found the avant wouldn't start due to a flat battery. Without any time to investigate I took the battery out and put it on charge and went to work in the wifes car.
After work I put the now fully charged battery back on and the rad fan started running. At least this explains why a four month old battery had gone flat. Pulled out the three rad fan fuses and the fan kept running. Put them back in and pulled the rad fan relay and the fan kept running. Put that back in and pulled the rad fan delay relay and the fan stopped. This relay looked a bit overheated and there was white stuff around the mount for it so I figured the relay had burned out and put the rad fan relay in its place. The fan started running so it's not a burned out relay.
What do I need to look at next? Is it safe to drive the car around with the rad fan delay relay removed? What does it do anyway?
One small clue I have is that when I was reassembling the air filter housing earlier this week after cleaning the MAF as pushed the top down to fasten the clips the rad fan ran momentarily. Is there anything I could have shorted out underneath the filter housing?
I'd appreciate your help on this one chaps. I'm due to drive up to Scotland tomorrow morning to see my dad who is in hospital after having a heart op. I can't even begin to think that I may not be able to go.
