Walbro v Bosch 044
  • Dift
    • Nov 2014
    • 282
    Walbro v Bosch 044
    Which pump is the best choice for a RS2 spec URS4?
    Both can provide enough fuel, however which is easier to fit in the standard basket?
    Ideally I don't want a noisy pump either.
  • GazzaG60
    • 4133
    i have a walbro 255. was labelled a holley FI pump but its a walbro. its basically the same size as a stock aby pump.
    i did not use it though as i got 2 044's instead. in tank you should imo hear neither.
    the walbro is a fair bit cheaper but not as high flowing
