Hi,
After long months of desperate fight with electrical gremlins in my ersatz urq project wiring loom, and burning to near-death state three ecu's, I finally managed to start the engine . "New" ecu, is from S4 AAN with automatic gearbox. After heating the engine, I've did some test runs on the snow. It revs up like before , pulls like before. Cannot test boost level on the snow (0.2bar and it looses traction) but it seems ok.
BUT! Revlimiter is on 6500-6700rpm range (was in 7000-7200 with ABY ecu),
also engine is refusing to drop rpms in sports car style, when throttle is closed rapidly. It drops revs smoothly like KE-Jetronic based KV engine .
Also this ecu is not responding to the K-Line for some reason (VAG-COM).
Should it behave like that ?
Sau
P.S. VAG P/N 4a0 907 551 B still havent opened it to check with firmware version i is in it .
Sau
