ngk plugs?? any good
  • Monkeymagic
    • Mar 2012
    • 3419
    I've just serviced my stock 3b Andrew page supplied me a new set of plugs which are not pfr7b platinum which have replaced the rather corroded Bosch oe items.
    Will they be Up to the task knowing how temperamentAl these engines can be?
  • Michael S2
    • Dec 2011
    • 1378
    I will be using NGK BKR7EIX when i change my plugs soon. They need gapped to 0.6mm as per o.e. Bosch plugs, out the box my NGKs are about 0.75mm.
    1995 Audi S2 Avant
    • Monkeymagic
      • Mar 2012
      • 3419
      All seems fine. So ill give them a little test I guess
        I was recommended the 7eix from JP.
