The pesky little turbo coolant hose has started to weep on my s2 Avant, so im going to replace all the coolant and ancillary hoses with silicone ones in one hit. The Roose ancillary kit has no bleed tap in the heater pipe at the bulkhead, does this cause any problems bleeding the cooling system?.
Roose ancillary hose kit.
Easy solution is to drill a small 2mm hole in the top of the matrix tube, then to bleed it you just need to slide the hose forward on the pipe to uncover the hole and bleed any air out, the just push the hose home and torque up the hose clip.
