I recently replaced the clutch in my RS2 with a southbend stage 3 clutch and a resurfaced 7A steel flywheel. I'm not sure if it's related but my car is now idling rough. I'm getting a flutter at idle and it continues when the engine is revved.
I've checked the obvious. Electrical connections, replaced the spark plugs, checked the injectors (every disconnected injector caused the engine to run rougher so I don't have one bad cylinder). Checked the MAF connector.
I binked the codes but there are none stored.
It almost seems like the timing is off. Could there be an issue with the 7A flywheel? I know others have done the swap with success.
The car sat for about 8 months with a full tank of gas. I can't remember if I used stabil in the tank. Could the gas be stale?
I'm running out of ideas.
Thanks,
Dave
Thanks,
Dave
