Is anyone in europe making an alloy crank pulley for the 10valve i5 engine?
Aluminium Crank Pulley
Tags: None
If you are really in the US like your home flag says, EFI Express sells Tommi's Billet.com alloy crank sprocket.
http://www.efiexpress.com/catalog/pr...products_id=23
Otherwise, if your Finnish is up to it, Tommi has it at his website:
94 UrS4 V8 6 spd manual avant -
ok.... in order to keep the terminology correct....
It's a "v-belt pulley with vibration damper" according to vagcat
Aluminium or Aluminum are equally acceptable....Comment
