Audi s4 2.7t turbochargers removal
  • mac2226
    • Jun 2008
    • 1289
    My friend has wear on his ko3 turbos on his s4 v6 bi turbo is it a engine out job to remove these or can it be removed from under car on 4 poster? Not looking forward to removing these I can see it been Engine out job
  • prj
    • Mar 2010
    • 6308
    It is possible to remove them without taking the engine out, but I would advise against it, it's quicker to take the engine out.
    Alternative is gearbox off and then go in from the rear. But again, it's easier to drop engine and box down together, change them, and then put it back in.
    Don't forget to use a pressure tool T-d into both actuators and verify that both actuators open and close at exactly same time on the turbos, as otherwise you might be pulling the engine again soon.
      Anything 2.7tt and especially the *K*03 turbos (time to go *K*04s is now BTW) is:
      1. Step 1 - remove engine from chassis.
      • prj
        • Mar 2010
        • 6308
        Originally posted by UrS4boy
        Anything 2.7tt and especially the T03 turbos (time to go T04s is now BTW) is:
        It's K03, not T03. Big difference.
        Also, the step is:
        1. Remove engine from chassis or remove gearbox from chassis (or both). Or alternatively they can be changed in-situ, but it is so hard to get to certain bits and bolts, that it's not worth the effort. Better to drop the engine down somewhat together with the box.
          That is funny. I typed K03 and K04 but for some reason, thought that was wrong and changed K to T.
          Anyway...
          Step 1. - sell 2.7tt-equipped vehicle
          Step 2. - buy AAN/ABY/ADU equipped vehicle where you can actually see and replace things.
          • Morris400
            • Sep 2013
            • 123
            Engine out .
              Originally posted by Morris400
              Engine out .
              "Engine and gearbox complete" out.
              • mac2226
                • Jun 2008
                • 1289
                Thanks every one for advice
                • prj
                  • Mar 2010
                  • 6308
                  Anyway...
                  Step 3 - enjoy complete loss of handling properties of the car.
                  2.7TT is much nicer to drive than the 2.2T, and it's not just due to the increased displacement. Try an actual RS4 sometime Dave.
                  P.S.
                  I recommend dropping the gearbox and the engine out together, it's a huge PITA to get the engine onto the gearbox when you are putting it back in if you don't. BTDT.
                  If you need to work on the trans anyway, you can take just the trans out and access the turbos from the back. It's not pleasant, but completely doable.
                  • Giacomo
                    • Apr 2014
                    • 523
                    • Country: Italy
                    somewhere on audizine there's a link to a video that shows engine+tranny removal step by step.
                    I agree about S4 handling. Very funny, the car seems normal A6 C4 chassis with 2.2T.
                    • chris
                      • Jan 2008
                      • 365
                      s4
                      i will keep my fingers crossed [and toes] that my new daily stays healthy, allroad 2.7 tt,with 6 speed, recaro interior,
                      does go well ,, but is there any recommendations for tuning to 300 brake?
                        That would be tricky since we didn't get any over here.
                        Anyway, I like the C4 just fine and don't like multi multi link front dog bone suspensions.
                        • andy10v
                          • 5996
                          Now going off topic
                          What dont you like about them?
                          Sold ABY-stock
                            They wear out and there are too many of them and they aren't inexpensive (for good ones). Yes, I understand the C5/B5 suspension is "better" but sometimes, simple is better than complicated.
