Help! Oil in coolant after head gasket replacement
  • EvenM
    • Nov 2010
    • 184
    • Home: Sweden Current: Norway
    Hello.
    I have a little nightmare with my S2 I have replaced the head gasket and after the first test drive its oil in the coolant reservoir and under minimum with oil on the dipstick.
    What should I check first? Leaks around the new head gasket? Drain the oil and coolant?
    Regards
    Even
  • SteveH
    • 4460
    Originally posted by EvenM
    Hello.
    Regards
    Even
    Did you resurface the head when putting it back together? Why was the gasket replaced? If it was due to overheating or failure you would certainly need to check and resurface the head. I would suggest either the gasket hasn't sealed properly or you have a crack somewhere between the oil and water channels. Probably a head off and test scenario unfortunately!
    91 Modded 3B
    14 A6 Avant Black Edition
    • EvenM
      • Nov 2010
      • 184
      Thanks for quick reply. I replaced it because I had white smoke coming out of the exhaust. Did not overheat. Did not resurface the head, but is that necessary? A friend looked at the head and said it was good.
      • simon20vq
        • Dec 2010
        • 1379
        Could it be oil from when the head gasket first went? However as SteveH said the head would have needed checking first before fitting to be 100% safe
        • EvenM
          • Nov 2010
          • 184
          I thought so too first, but under the test drive the engine used oil and there is no oil leaks, so have to go in the coolant I think
          Nothing else to do then, just take of the head again and start from scratch:
          Should I flush the cooling system with anything before taking everything apart?
          • mike74
            • Apr 2014
            • 615
            If its leaking that much oil into the coolant then flushing right now probably isn't going to achieve anything. I'd get the head gasket replaced and then replace the oil & coolant. Once you're sure there isn't any more leaking then certainly run a flush through to remove oil residue from coolant and replace.
            • EvenM
              • Nov 2010
              • 184
              Okey, thanks
              • ChrisG
                • Jan 2005
                • 68
                Not sure about these cars but many Audis have a small heat exchanger between the oil filter and the block
                [ warms the oil up ( when engine cold) and helps to cool down ( when coolant up to temp)]
                These can eventually fail internally and mix the two liquids. Possibility - if fitted to S2s ??
                I had to replace one on an 80 Sport after 20 years !
                £ 45 approx from the dealers.
                • irishs2
                  • Apr 2009
                  • 2455
                  Could the oil/water exchange be happening in the turbo?
                  Eric
                  95 S2 Avant under rebuild.
                  • EvenM
                    • Nov 2010
                    • 184
                    I have replaced the org turbo for a used rs2 turbo , could that mix liquids?
                      I think this is more of a Mk 2 Golf vintage type thing, and a similar vintage 4 cylinder Audi engine.
                      Don't think it applies to an I5.
                      • SteveH
                        • 4460
                        Oil sandwich plate. S2's don't have them
                        91 Modded 3B
                        • 220bhp
                          • 2578
                          • Home: United Kingdom
                          Did you check the head for corrosion around the water ways. It is quite common on these heads where the wrong coolant has been used in the past.
                          Heads should be pressure tested and checked for straightness when taken of, and if necessary be machined.
                          These heads are now over 20years old. that's a lot of heat cycles.
                          Best of luck getting it sorted
                          • EvenM
                            • Nov 2010
                            • 184
                            I'm not sure, I had someone to look at the head. Thanks for the tips, better check those things this time
                            • EvenM
                              • Nov 2010
                              • 184
                              Update: I found two places on the turbo side where it looks like oil is coming out from the head gasket, should I try to tighten the arp studs more? I have not tighten them after test drive.
