Oil filter housing gasket NLA?
  • martinjs
    • 3205
    My local TPS told me yesterday that they can't get these anymore. (Round one onto the block)
    Anyone buy one recently?
  • Monkeymagic
    • Mar 2012
    • 3419
    is it a rubber o ring or paper gasket.?
    • Rusty
      • 18953
      I'm certain one came with my Reinz head gasket kit...
      • martinjs
        • 3205
        It's a paper one.
          External Oil Lines including Oil Filter Bracket info
          Paper. Item 9. 035115441B
          Face it folks. At more than 20 years old, it is not surprising that Audi is starting to let the spares bin(s) go empty. We're going to have to start improvising, including (re)learning how to cut gaskets from rubber sheets, cork, etc. just like your father or grandfather did before or after WWII when things were either pricy or scarce.
          C4 AAN External Oil Lines:
            One Google result:
            https://www.fcpeuro.com/products/aud...vag-035115441b
              It's in the Reinz bottom end gasket set.
              Reinz also supplies the raw material for you to cut from, as Dave suggested:
              • rxl
                • 1913
                Reinz did the gaskets for the audi rs2 s2 so its OEM.
                • martinjs
                  • 3205
                  Where would you buy the bottom end gasket set Alex?
                  Does it have front and rear crank seals in it?
                  • andy10v
                    • 5996
                    My dad just gave me a set of gasket punches, and explained how to lay a gasket on the manifold (or whatever you want a gasket for) and tap lightly round the edges to create the outline.
                    He suggested a coupe of sheets of gasket paper are very handy to have around, especially when fixing something at night to use the next day.
                    Sold ABY-stock
                    • mouse
                      • Apr 2008
                      • 374
                      • Country: Australia
                      Cardboard from cereal boxes can work too
                      Don't worry none on my S2 but used to use them on an old dirt bike I got when I was 15 - 16 (many years ago) ..
                      • andy10v
                        • 5996
                        That was also mentioned, I think much worse may have been used in the middle of a rally!
                        Sold ABY-stock
                        • Johnny86
                          • Aug 2016
                          • 2
                          I can offer this gasket, if anyone still needs it.
                          I also have lots of other gaskets and custom stuff for those R5 20V engines.
                          Custom Audi Parts
