HELP PLEASE!!!! Audi S2 Wastegate, Turbo and N75
  • Apow
    • Jan 2012
    • 19
    Hi all,
    I need some advice please!!!
    I have a project car Golf mk3 2.0ltr ABF 16v Turbo. Running DTA S40 PRO managment
    What i would like to know is what goes where...
    Do i need a N75 valve?????
    N75 - F version.
    T piece connection
    Long horizontal connection
    Short horizontal connection
    and connection point down.
    Audi S2 Turbo
    Where does the connection on the compressor housing go to? (this is the tiny pipe that stick out to where the air filter connects)
    Audi S2 Wastegate (With adjustable hex nut on top, also the is vented to atmosphere)
    Top connector of wastegate
    Bottom Banjo connector on wastegate
    Any help or diagrams would be appreciated on how all these should be connected together
    Many thanks all.
    Sorry. It is difficult to understand what you know and don't know about the basic Audi 20V turbo system from your questions. Here are some links and diagrams that might (or might not) help you:
    N75 info: http://forums.quattroworld.com/s4s6/msgs/20987.phtml
    By-pass Valve info: http://forums.quattroworld.com/s4s6/msgs/20994.phtml
    • Apow
      • Jan 2012
      • 19
      Thank you very much. This is very helpful i will check it against my current setup tomorrow!
