My Bosch 044 pump died after approx. 9000 miles of use.
Bosch says 500 hours maximum pump life on E85 (ethanol) with these.
I probably got around 175 hours out of it, so not buying a new one.
The Walbro GST450 looks like the most viable alternative right now, as it has better capacity than the 044 and it is approved for E85.
The fact that it costs around £100 less is another plus.
Upper section is 39mm OD, while lower section is 50mm.
The current 044 sits in its 60mm V8 basket, so will likely find some way to secure the Walbro in that one with a bushing that I will make from neopren or silicone.
The stock RS2 basket that I still have is for a 40mm pump, so that won't work.
EDIT: doing some more research, it seems that it could be close to plug and play in the stock RS2 filter holder/basket, by using the Walbro sock strainer instead of the stock Audi one.
Anyone with any experience with the GST450?
Install tricks?
Install tricks?
