PAS Pump replacing
ETKA tells, that 054 145 155 B is used only in A200tq 20v
can't figure number of second pump (that 100/s2/s4).
Of course there can be mistake, but ETKA gives three numbers of PAS pumps for your car
Don't know what this means, but ir seems, that these part numbers are for refurbished units.
SauAttached Files200 20vt 88' 3b, human carrier
Can someone tell me if the following pas pump will fit in my s2 3b,
http://cgi.ebay.de/ws/eBayISAPI.dll?...sPageName=WDVWGetting everything sorted out for my 5++ hp project
Its pretty straightforward... going on memory here -
1. Decativate the bomb with lots of brake pedal pumps (engine off) until pedal goes hard. You MUST do this first or you risk personal injury when loosening high pressure PAS fittings on the pump.
2. Remove trim panel above main radiator.
3. Disconnect PAS line where it meets the cooler hose in front of the radiator - this drains *most* of the fluid out of the system - don't reuse it.
4. Loosen the two high pressure PAS hoses from the pump - you need largeish sockets for these - 22 or 24mm IIRC. Carefully remove the O-rings with these bolts - they should be renewed of course. Prepare for some fluid loss here of course.
5. Loosen the 13mm hinge bracket bolt on PAS pump - nearest engine
6. Loosen the PAS belt tensioner - 13mm again - nearest the radiator side. This is a threaded bar used to position the pump correctly. The pump will lower gradually as you loosen this bolt. Keep going until you can slip the belt off.
7. Remove the hinge bolt where the pump mounts onto the engine - be careful not to drop the inboard nut as you may never see it again !
8. Now you can remove the PAS pump by hand - you'll have to tease the low pressure hose (where it connects to the cooler) through the hole in the ducting under the pump.
That's as much as I can remember ! Refit is reversal or removal... Don't lock the hinge bolt until you have PAS belt properly tensioned... and check the cleanliness of filters in the high pressure banjo bolts.
PaulPaul Nugent
Ok, thanks paul you a real help .
Will do it tonight, so I can send it to a mechanical repair centre tomorrow. Told me it would only take them one day to repair. Hope to have it back on saturday or monday.
costs: 210 euro , one year warranty.Getting everything sorted out for my 5++ hp project
Good oh !
PaulPaul Nugent
I think I might have to replace my PAS pump also before too long.
When I had the belt off, if you turned the pump by hand it had a very distinct tight spot - this surely cannot be right.
Probably explains the odd noises it makes from time to time.
Could someone confirm that a nice new pump should turn sweetly with no tight spots.Glyn
Ex-Polar Silver RS2
Sprint Blue RS4 - new toy :mischeif:
i picked up my new one yesterday and it turns very freely with no tight spots at all. there is a bit of end float but i seem to remember reading that this is normal.
If you move the aux rad it makes this job a lot easier and doing the thermostat at the same time is a good idea.
oh, and don't overtighten the pas pump belt as this will wreck the pump, btdt.
Phil
Excited that I might be getting my car back today after 2 weeks driving rubbish mg rover 25 thing
Originally posted by Phillioi picked up my new one yesterday and it turns very freely with no tight spots at all. there is a bit of end float but i seem to remember reading that this is normal.Glyn
Ex-Polar Silver RS2
Hi All
By coincidence, again, my pas pump too has just started making strange noises! Is wear on the pump related to age of car, or number of turns completed !!!!
A long while back car had incorrect fluid in it, courtesy of local garage, how much would this have contributed to pump failure?
Regards
Ian'91 3B Coupe
