Hi Guy's, I have a problem with the cooling system. The fan (stage 2 en 3) wasn't kicking in on idle. While drivin I don't have that high temperatures. I checked de fan by using a wire an connected the pins on the thermoswitch. Fan is working properly. So replaced the thermoswitch but nothing changed. Checked both (old en new) switches in boiling water and they where fine. So the temperature under in the rad is lower then it schould be. I also notice the difference in temperature between the lower en higher hoses on the rad. The systems is bled like it schould be. What could be the problem? Blocked ar partially blocked radiator?
overheating on idle
hi bart
as long as the thermostat remains closed, it is normal that there is temperature difference between the upper and lower radiator hose
do you have change the thermostat? maybe he does not open........
you can always call me
cheersaudi coupe quattro b2 2.2 20vt project (573hp-626nm)
TWINCHARGED power,zero lag
AEM W/M injection
I found the problem. First I checked the thermostat but it seems okey. Then I removed the rad and try to get some water true it. It wasn't flowing. Also in the opposite direction I couldn't get any water true the rad. Apparently the small radiator in front was good enoufh to cool the engine down a bit wihile driving during the winter. I hope the engine (espacially the head gasket) is still good after a few overheating moments
