Hi
Can anyone help identify my engine block?
Just cleaning the block ( taken out of my 1992 3B coupe ) and I am puzzled!
There is no engine no, the no on the block is 054103021, which doe's not seem to fit with what should be in a 3B. There is 25L and 91 cast into the block, the bore is 80 mm, I cant measure the stroke unless I put the crank and a piston back in but the rods are about 144 mm. Any help appreciated.
