HELP!! My Audi S2 still wont start!! :(
  • eXtreemeRS
    • Feb 2005
    • 56
    Hi!
    Got a Audi S2 2,2 turbo 92mod.
    The car just stopped one day..I suspect the electric..
    It seams like the brian of the car dosent get 12v power..
    Anyone got a manual of the wiering form the fusebox and out??
    The fuel pump should start for a few sec when I turn the ignition on..
    I dosent.. There is no sparkel out from the coyl..
    But I can open the rele for the fuel pump and start it manualy.. then I can hear the fuel pump start.. but the car still dont...
    I have now changed the fusebox and all the fuses + all of the rele's.
    I have changed the ignition lock.
    I have checked the Hall sender, and it's ok..
    I've replaced the controll unit (the brain)
    Anyone got any idea's???
  • kwlw
    • Sep 2004
    • 1025
    • Country: Lithuania
    Replacing is good, however not perfect solution.
    I suggest you, check what is going on. Take electrical schematics, and check what is ECU seeing in terms of voltage and ground - I mean check the connector pins with ignition on, ignition off. Most of testing can be done with simple multimeter. After that try to read ecu errors using some VAG-TOOL, or just read the blink codes (you will find info how to do this in pages below). If ecu is OK, and voltage and ground inputs are OK, it will tell you, what is wrong. BTW don't be scared if ECU will give single error "Crankshaft reference sensor blah blah", it should disappear after you make several turns of engine with starter.
    Pages which can help you:
    Discover the latest breaking news in the U.S. and around the world — politics, weather, entertainment, lifestyle, finance, sports and much more.
    Don't know which engine do you have, however these pages provide info, how to test many things.
    Sau
    • eXtreemeRS
      • Feb 2005
      • 56
      Ok!!
      I got a 3B engine.
      thanks.. I'll check the web pages u gave me!
      There is something strange going on here..
      I have some work to do!! again thanks!
      • eXtreemeRS
        • Feb 2005
        • 56
        VAG Tool!!
        Do u know where to get the VAG-TOOL??
        • kwlw
          • Sep 2004
          • 1025
          Make you own, lend from someone, buy . There is number of options. My friend makes those, so I don't know where to get them elsewhere.
          I suggest you to visit http://www.s2central.net/blinkcodes.html page for blink code info.
          It contains information what to connect, where to connect in s2.
          Good luck fighting that gremlin, which made itself home in your es2 .
          Sau
          • eXtreemeRS
            • Feb 2005
            • 56
            Sau
            hmm.. so the VGA-Tool is not a software that I can install on my laptop..?
            Is it a external box? sure I can build one, but need instruction manual on how to.
            I'll enter my garage at this time.. if im stuck.. maybe I can
            hook up my cam in the garage so u can watch me blow up the car..
            hehehe...
            anyway... of to the garage!!
            • S2 Ant
              • 3682
              You dnt have some kind of aftermarket immobiliser causing a problem do you?
              Ant
              2011 Kawasaki Z1000
              • eXtreemeRS
                • Feb 2005
                • 56
                Hmm.. maybe... if I understod what aftermarket immibiliser is..
                Form Norway.. not so god in english..
                • eXtreemeRS
                  • Feb 2005
                  • 56
                  Connector Assignments on ECU! Wierd!!!
                  Sau
                  So.. I've check the connector pins with ignition on, ignition off useing a multimeter.. I only got 12v on pin 2 and 17 with ign. on. With ign. off I got 12v on pin 2 only.. Sounds wierd to me.. got an idea..? Is this right??? anyone got a color code schmatics for the wiering from ecu???
                  Pin 2 is Coding Plug
                  Pin 17 is Injector 1
