Crankcase breather removal
  • mac2226
    • Jun 2008
    • 1289
    I've been told it's hard to refit the metal crankcase breather back on as I need the little metal pipe deleting which goes to the back of the head and fitting some new breather hoses into a swirl pot I could just block it at one side bit id rather just remove it all together any body btdt could share how they did there's when fitting a swirl pot and oil catch can
  • K Simmonds
    • Dec 2007
    • 7627
    I wouldn't attempt to remove one of those again unless it's 100% necessary, their NLA and a sod to fit in situ, I made the mistake of removing mine to weld an AN fitting to it and had to use chemical metal to get it to seal properly.
    With the engine out on a stand it's not a problem.
    1990 B3 2.0 80 quattro.
    1992 C4 2.8 Avant quattro
    1994 MTM RS2.
    1998 B5 TDI quattro Sport.
    2000 B5 TQS.
      I am not clear what you are trying to do but if it is just adding in a catch can, then you want it *AFTER* all the crankcase ventilation bits. Mann ProVents are very user friendly for this application. Location would be something like this:
      • mac2226
        • Jun 2008
        • 1289
        Sorry my mistake it's sorted now didn't realise the smaller metal pipe that joins with main crankcase was in two pieces
          AAN/ABY/ADU Positive Crankcase Ventilation (PCV) System with revised diagram, PNs and
          Would this have helped?:
          AAN/ABY/ADU Positive Crankcase Ventilation (PCV) System with revised diagram, PNs and Links
          http://forums.quattroworld.com/s4s6/msgs/22506.phtml (also here somewhere)
          • mac2226
            • Jun 2008
            • 1289
            Yes that would of been great at the time urs4boy the crimp jubilees was covered in oil and crap so couldn't tell at the time till I sprayed Some brake clutch cleaner on the crankcase breather and realised
