Sump bolts loose
  • Rikki Kitto
    • Feb 2010
    • 6276
    Sump bolts loose
    Anyone had problems with their sump bolts working loose over time, just noticed some of mine have disappeared and a few are loose. Is there a torque setting for them suppose I should of checked them after the first 1000 miles of new engine being in really
  • mac2226
    • Jun 2008
    • 1289
    I usely use a 1/4 ratchet with 6" extension and tighten them up with a little bit of medium loctite don't no (NM) that's why I use medium loctite can easily be undone
    • Thuppu
      • 4115
      Haha, after my first build I did loos all bolts from the sump except one in the front and the 8mm in rear. I did wonder why it's dripping oil.
      • andy10v
        • 5996
        Mine were all loose after a few heat cycles after replacing the sump gaskets, they had been torqued to spec the first time, I just tightened them all by hand the second time and no issues since.
        Spec is in the manual on mikes site if somebody cant remember it.
        Sold ABY-stock
          10nm for M6, 20nm for M8. I'm going to check mine tonight
          • s2driveruk
            • 12696
            i'll be doing the same having read that!
            1992 3b S2 Coupe
            • Rikki Kitto
              • Feb 2010
              • 6276
              I wasn't even checking them I was under the car fiddling with the bottom radiator mount and noticed the sump was wet, started to look at the nuts and noticed a few holes where there should be bolts
              • LHD_Kid
                • May 2006
                • 3695
                Mine was missing a couple with most only finger tight when I bought the car. Deffo worth checking !!
