My ABY-engine is always running rich.
Fuel consumption is up and turbo boost is down. Via VagCom I get fault codes 00525 and 00537 (O2 sensor short to ground and adaptation limit exceeded).
Lambdavalue in Vagcom at idle is 1,25, suggesting i lean mixture.
This is what has been tried so far:
Replaced O2-sensor.
Measured ECU coolant temp sensor and intake air sensor, they measure okay.
Tested signal wire from O2-sensor to ECU. Checks out okay.
Tested heating to O2-sensor. Tested okay.
Cleaned earth points at intake.
Switched injectors for another used set.
Multifunction sensor was new from Meyle a few months back.
MAF was new from Bosch 18 months ago, I have not tested it.
If voltage at O2-sensor is tested at idle, voltage is about 0,960 volts - suggesting a rich mixture, quite the opposite of the value I read from the ECU in VagCom, but a more trusting value since being behind the car smells unburnt petrol.
Another strange issue is that the lambda value in VagCom is the same with the O2-sensor connected as it is disconnected.
Has anyone got a clue as to why my engine is running rich and turning codes?
Replaced O2-sensor.
I've ordered the g62 sensor as this could cause these symptoms.
