Engine mounts
  • Rusty
    • 18953
    Engine mounts
    Other than stock, what are people using?
    I don't want the car to rattle itself to bits at idle, so some compliance is a must...
  • Thuppu
    • 4115
    AnLe "motorsport" ones are good.
    • k.alle
      • Feb 2008
      • 801
      Im using these, seems good enough:
      Audi S2 -1994 | 480 Hp 650 Nm | FlexFuel | MaxxECU | 3" Stainless | Porsche GT3 Front Brakes
      http://www.garaget.org/?car=52877
      • rxl
        • 1913
        got bambrige ones for my rs2 stroker.. didnt test it but looks quality
          Originally posted by k.alle
          How do they compare to OEM in terms of vibrations and noise in the car?
          Thanks
          Alex
          • k.alle
            • Feb 2008
            • 801
            Thanks
            Alex
            I haven't had the best luck with my car lately so I haven't been able to test them extensively.
            They are definitely harsher than stock but not annoying imo.
            If the engine itself idles nicely then I think all will be good.
            No more stick movement though, that's for sure!
            • steverrquattro
              • Oct 2006
              • 787
              I'm using Bambridge ones and they're good. Same for gearbox, rear diff and top mounts.
              Steve
              1990 RR 20V
              1982 SWB UR - RS2 Engine
              • vonbeck
                • 2455
                Hi Andy what did you end up using?
                • Rusty
                  • 18953
                  I got some secondhand poly ones but haven't fitted them yet. If I like them, I'll look for some new ones, if not, then I can get OE ones from Audi tradition
                  • SteveH
                    • 4460
                    I have Bambridge (Kev's) and they do create a fair bit of vibration. I wouldn't recommend them for a daily runner unless you are ripping the standard items apart.
                    91 Modded 3B
                    14 A6 Avant Black Edition
                    • Rusty
                      • 18953
                      Kev used very stiff poly, so something a little softer may be better. Will wait and see - with the rest of the poly and solid mounts, things are getting more and more hardcore
                      • vonbeck
                        • 2455
                        No I don't want my teeth falling out poly bushed the rear last year ,which is stiff enough thanks
                        • Tango23
                          • Jun 2010
                          • 427
                          • Home: United Kingdom Current: South Africa
                          Not wanting to hijack your thread ...but, I am in the market for a set of gearbox and engine mounts from Kev (Banbridge) if anyone has them spare....please PM me!
                          Cheers Fellas
                          Sean
                          • Rusty
                            • 18953
                            I got offered a full set in my wanted thread
                            • Tango23
                              • Jun 2010
                              • 427
                              Thanks Rusty!
