rs2 coolant expansion tank
  • Eastcoastrs2
    • Sep 2013
    • 95
    • Country: Australia
    Any recommendations on what brand/where to buy an expansion tank and power steering reservoir for an rs2?
    It appears my expansion tank is leaking from the coolant level sensor and the power steering reservoir from a small crack underneath as all hose joins seem to be free of leaks and there is no residue down the side of either one or leakage from caps only fluid underneath.
    Both appear original so it's probably about time anyway.
    Dealer for the Coolant tank, cheaper in the long run. Not hugely expensive.
    Not sure how much a power steering reservoir is. Google the oem part number and see what comes up. Maybe Febi or someone make a decent one ?
    • saltinot
      • May 2004
      • 1946
      David is correct. The aftermarket ones are not great quality and fail prematurely. Original Audi part is the only way to go here.
      8A0 131 403
      I bought one a few years ago now for my RS2....still hasn't seen coolant yet.
      • saltinot
        • May 2004
        • 1946
        Forgot to add.......RS2/S2 ABY hydraulic reservoir number is 8A0 422 371 D
        • Eastcoastrs2
          • Sep 2013
          • 95
          Thank you both for the info and tips and especially part numbers. I hope the time comes soon saltinot.
