AEL having strange noise see detail
  • Joop
    • May 2015
    • 89
    Hello,
    after my mechanic change the timing belt and waterpump
    it has still strange noise-before repairing i was told there will be no
    strange noise anymore.
    Please help me
  • Petu
    • Jan 2012
    • 61
    Is the engine hot in this video? The visco should not be going so fast. You should be able to stop the visco fan with your hand but your fan seems to be going too fast. I would try removing it and see if there is any changes. I have experienced stuck visco on my own car.
    Is the V-belt tensioner straight and not bent? The tensioners usually tend to make squeaking noizes the most on AEL-s.
    How is the noise when you stop the engine?
    • Joop
      • May 2015
      • 89
      Hello Petu,
      Thank you for your reply.
      after spraying some water to the power belt the noise
      is dissapeard.I ordered the new power belt i hope it will
      solve the issue but if not i need to replace the tension too
