Small Oil Leak
  • bilko0795
    • Feb 2011
    • 1883
    Small Oil Leak
    As per title i have noticed a small spot of oil on the floor from the front of the car, would this be coming from the crank oil seal ? I did the belt change a few months ago and i forgot to replace the pulley washer before starting the car that's when i noticed i hadn't replaced the washer i did take all apart and replace it so i'm wondering if this would have damaged the seal.
  • Monkeymagic
    • Mar 2012
    • 3419
    Yes or oil pump to block gasket which I have done too.
    • bilko0795
      • Feb 2011
      • 1883
      Cheers i will check it out.
