Hey peeps!
Been searching for a post regarding the power limit for an ABY engine with modded turbo and injectors, but without luck - In other words, how much effect can you pull out of the engine without getting engine casualties if you just upgrade the turbo and the injectors + fuel pump etc without opening the engine and switch out pistons, rods, shafts and so on?
Best regards
Best regards
