Custom parts 3" downpipe
  • Allanagtig
    • Jul 2015
    • 139
    • Country: Denmark
    Does anyone in here run with a 3" downpipe from custom parts? If yes, what are your thoughts and what type of turbo can possibly be mount on it or (what do you have currently on?). Was thinking a GT30 or Precision myself, but I dont feel like buying the downpipe if it only fits to the standard turbo
  • AndyP
    • 6049
    You can get all the parts you need from Ebay, just search for 3" or 76mm stainless
    • Allanagtig
      • Jul 2015
      • 139
      • Country: Denmark
      You make it sound easy Cant seem to find anyone. Been searching on the german and the .com one. If you got a link, please share
      • DJones
        • Jun 2005
        • 2020
        No links I'm afraid but like Andy I just found and ordered the tube from eBay and the fittings and rear box from Jetex and got an engineering company to cut me a flange to fit my turbo. Stainless mig welded it all together job done..
        Darren
        • AndyP
          • 6049
          Try these sellers:-
          • Allanagtig
            • Jul 2015
            • 139
            • Country: Denmark
            Ah okai! Thanks for the links. I get you Andy I have to make an exhaust myself out of parts I was looking for a complete piece as I dont have any TIG or MIG welding machines or welding knowledge when it comes to stainless steel
            • diesel des
              • 3896
              Welding stainless is just like mild steel. If anything it's easier. Just use stainless wire or rods.
              Welding alloy is the more difficult material.
              • Laaf
                • Oct 2010
                • 275
                You mean this one? http://webshop.cp-service.se/sv/audi...s2-rs2-s4.html
                It fits the standard turbo and wastegate with the standard or RS2 exhaust manifold.
                • Allanagtig
                  • Jul 2015
                  • 139
                  • Country: Denmark
                  Exactly Laaf If I wanted to use a different flange for a larger turbo id have to cut away the already existing flange and weld on a bigger one?
                  • Laaf
                    • Oct 2010
                    • 275
                    It depends on what turbo you intend to run. Atleast RS2 turbo fits no problem. May be other bigger KKKs too that will fit.
                    Bigger Garretts and others I am pretty sure it requires a bit more modification. They do make custom downpipes if you send them the exhaust housing you intend to use. If you have another manifold than standard or their tubular manifold you have to send it to them too.
