hi all, im thinking of mounting the the oil cooler where the aux radiator used to live , firstly would this cause a problem with circulation in any away, also I would have thought it should be lower than the oil filter , but tbh theres no space would it be ok behind the grill cheers
oil cooler where can it be fitted
Lots of folk have used the aux rad position without issues.hi all, im thinking of mounting the the oil cooler where the aux radiator used to live , firstly would this cause a problem with circulation in any away, also I would have thought it should be lower than the oil filter , but tbh theres no space would it be ok behind the grill cheers
There's plenty of room in front of the main radiator and you can easily route air from the lower grill directly onto your oil cooler. That's what I decided to do and it was very easy to get a 19 row cooler down there with a simple bracket.
91 Modded 3B
14 A6 Avant Black Edition -
Get one of these of Vidar Skothiem they fit in original position
Attached FilesComment
No issues, only slight annoyance is it blocks access to the timing belt cover if you are messing with the cam wheel, same as the aux rad. Not really an issue though.
My hoses were long enough that I could unbolt it from the crossmember and swing it up on top of the engine or airbox to access timing belt etc.Current-2004 Impreza PPP wagon
Sold ABY-stockComment
Must be ok enough in small rad position-remember urs had an oil cooler in the tailgate spoiler didnt they?Comment
