Car Won't Start After Changing Crank Oil Seal
  • bilko0795
    • Feb 2011
    • 1883
    As per title just changed the crank oil seal now the car won't start not sure if it's because there is no intercooler plus the hoses or if the problem could be these picks.
    Cant figure out why the timing mark on the camshaft has moved slightly.
  • Mikes2
    • 1704
    It won't start with the timing that far out.
    You'll need to remove the belt and adjust the cam timing
    Mike
    http://www.s2-audi.co.uk
    • bilko0795
      • Feb 2011
      • 1883
      How do i do that and has said i don't why it's out that much.
      • Mikes2
        • 1704
        you must have removed the belt to change oil seal
        Mike
        • bilko0795
          • Feb 2011
          • 1883
          I tied 2 cable ties around the camshaft to hold the belt in place and just took the belt off the crank toothed sprocket as i have done many a time the only thing that i did was on the main pulley and was turn the two parts in error, but they only go back the one way to line up the bolt holes to replace the big pulley to the crank.
          • maiks
            • Dec 2014
            • 295
            If U have not connected the intercooler and pipes are loose, then car does not start. Turn the engine several times because the marks aren't at the same place, on every 2nd round, marks should be in right place. I hope U understand what I mean.
            • bilko0795
              • Feb 2011
              • 1883
              Yes i understand what your saying.
                This is 2 teeth out. Too many for the ECU to see a good G40 cam sensor signal at the appropriate time.
                • bilko0795
                  • Feb 2011
                  • 1883
                  Cheers Dave
                  I know it's out but i can't figure out why it went this way i have done nothing different.
                    Correcting a timing belt that is one (or two) teeth out
                    Originally posted by bilko0795
                    Cheers Dave. I know it's out but i can't figure out why it went this way i have done nothing different.
                    Forget the "why" Just fix it. Here is a link to a quick fix (if you have the crank locked at TDC):
                    Correcting a timing belt that is one (or two) teeth out:
                    • bilko0795
                      • Feb 2011
                      • 1883
                      Thanks Dave , straight to the point as usual and armed with all the knowledge on all things Audi I5 I must admit I had forgot that doing what you have pointed out was the way to sort it I think I'm going senile in my old age
                      Thanks.
                      • Monkeymagic
                        • Mar 2012
                        • 3419
                        The reason why will be because you would have had slack.on leading edge of belt.
                        • andy10v
                          • 5996
                          Also if you want it to start with the intake hoses off you will need to unplug the MAF.
                          Sold ABY-stock
                          • pasbogdan
                            • Sep 2009
                            • 1160
                            • Country: Romania
                            Get the timing done first.
                              What? Don't you like the idea of valves being given a "Glasgow kiss" by the pistons if things are out of sync? (Not sure if 2 teeth off would cause an issue but I know a broken timing belt sure will).
                              Intake valves protrude into the combustion chamber:
