I didn't bother with putting new rivets in the headgasket - as the dowels keep all the layers in the correct position when it is on the head.
Make sure every layer is spotlessly clean.
Make sure the head is not dripping oil - remmber when you move and tilt it to get it on the block you might get drips of oil - this is not good it will get inbetween the HG layers.
I used a couple of small cable ties through 2 of the rivet holes just to keep the HG together until the head was in place.
