cooling fan on all the time
  • horvathg
    • Dec 2003
    • 556
    Is it normal that the cooling fan is on from the moment I start the cold engine? And I think the fan stops when I cut the engine, even if it is warm. What is this please?
    Gabor
    96 ABY coupe full except sunroof. With Porsche big red brakes, remapped ECU, xenon lights, RS2 MAF
  • RS2.pt
    • 155
    hi have similar problem, dont know if its normal.
    when I turn the heater on (without the AC) the fan from radiator turn on...
    • porkkis
      • 1994
      This isn't the first time I've heard about this.
      I have the older climate and it has different wiring so can't do much more than guess...
      Try to pull out the fan relays one by one and see what makes the fan stop. They're located in the fuse box in the back row. 2 or 3 of them.
      If it does not run when ignition is off then it probably has nothing to do with the after run cooling.
      If the climate unit makes the fan run (even if the AC is off) the obvious cause would be a faulty climate unit triggering the fan on even if the AC is off.
      Would need to have the schematics..
      • Gringo
        • Jan 2005
        • 139
        Not normal.
        Try installing a new temp sensor in your radiator. This sensor controls you fan and sometimes it sticks. Not an uncommon problem. Had the same thing on my car.
        Now you see me, now you don`t
        80quattro.com
        • porkkis
          • 1994
          Gringo how do you explain the link between rad temp switch and climate unit?
          • Gringo
            • Jan 2005
            • 139
            The climate control triggers one of the fans. When the climatecontrol unit breakes, its usually a ground related problem. Somehow the climatecontrol grounds the fan. SImply by replacing the climatecontrol from a mates car forexample would tell you if its the temp switch or the climatecontrol causing the problem.
            80quattro.com
