Audi UrS4 - Fault 00537 ( 2341 )
  • Brane_11
    • Sep 2015
    • 2
    • Country: Croatia
    00537 lambda oxygen sensor regulation
    11-10 control limit not reached intermittant
    Is it related to a faulty MAF sensor?
    No boost leak
    Change sparks
    Cleaned injectors
    Change Lambda sensor
    G39 Lambda Oxygen (O2) Sensor Info and Function with PNs
    * 2341 (Blink Fault Code), 00537 VAG1551/2 Fault Code Number
    Oxygen Sensor Control Limit exceeded,
    fuel pressure too low or too high, intake or exhaust leak, defective ignition system component, intake air leak after air mass sensor, O2 sensor is faulty
    Symptom: CO before catalyst is below 0.3% or greater than 1.0%, Extremely lean or overly rich exhaust, Spark Plug fouling.
    G39 O2 sensor info: http://forums.quattroworld.com/s4s6/msgs/21012.phtml
    AAN Boost Leak Testing: http://www.s2forum.com/forum/showthr...t+leak+testing
