Well if pcv system is clogged then the crankcase pressure will cayse the turbo seals to fail explaining the white grey smoke which also leads to heavy oil useage.
Help understanding compression test results
Car has 10/40 in it. entire pcv system is new, air filter is new, injectors have been cleaned, tested and serviced on a ASNU machine.
will check for fresh leaks, but im possitive the only one is a drip from the rear main seal, which had stopped because the oil level got so low,
i think my next step is to check turbo piping and intercooler for oil, intercooler was cleaned before being fitted so should be a good indication if theres alot of oil in there, for the moment the car has 10/60 in it up to about 3/4 mark as its all i had off hand. when oil cap is removed with engine hot or cold there isnt any real blowby, so i suspect that the pcv system is working as it should,1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
Checked the michelin man hose for oil and its bone dry, so i dont suspect the turbo
heres a video clip of how bad it is sorry for poor quality iphone video,
engine a 1500 rpm
https://youtu.be/wn2AhpUCe7A1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
Originally posted by stocious View PostChecked the michelin man hose for oil and its bone dry, so i dont suspect the turbo
engine a 1500 rpm
Is there water on the ground?
Oil burned does not blend so fast into air.
Originally posted by pasbogdan View PostThat does not look as oil,as good as it can be seen on youtube. Is there water on the ground? Oil burned does not blend so fast into air.
Head gasket issue? Turbo coolant issue? Cracked turbo center section leaking coolant (and maybe oil)?
