ABY toothed belt NLA
  • 220bhp
    • 2578
    • Home: United Kingdom
    #31
    Much as I love my three Audi I have to say the company as a hole stinks.
      That's because they are A S S holes
      • popdemonic
        • Dec 2007
        • 1304
        • Country: Thailand
        #33
        TJ: stock thermostat for I5 is 87c and you will also see
        This thermostat on V6.87c is also common used on
        merc and bimmer.the 71c thermostat is useless IMHO.
        My country is 35-45c all year round.my car never overheated.
        It's steady around 87-90c besides the f^*k aircon which
        Not blowing cold air when car is not moving under the hot day.also my car is not wrong.
        Since all I5 cars does the same ****** things.
        one of a few I5 from Asia.
        • vti2
          • Jul 2010
          • 281
          • Home: Portugal Current: Germany
          #34
          Are you sure you have a 87c thermostat? Audi put a cooler one on car that go to hot countrys.
          • veneto rs2
            • Jun 2006
            • 1022
            • Country: Veneto
            #35
            I wonder where you're sourcing this experienced infos.....
            The motor has been set by the people who developed to run in a fixed temperature range
            the thermostat it's used to determine the point when the radiators are requested to work and start to try to KEEP as better as possible that fixed temperature despite the outside temperature speed of the car rpms of the motor and so on.
            Hence thermostat closes and opens to keep the system on the selected temp because it could be that the motor could become too cold which as you've been told it's not good.
            In hot countries they will have put (they did not) bigger radiators NOT a cooler thermostat.
            I reckon You better go back into basics such as......
            How a petrol motor and the cooling system works.
            http://www.audisportclub.com/
            • vti2
              • Jul 2010
              • 281
              #36
              Just go to Audi and ask for s Tropic Thermostat. You will See they will give you one. They don't Build it just for fun...
              • jade
                • Jan 2005
                • 1811
                • Home: New Zealand Current: Spain
                #37
                We in Germany run our Cars at much higher Speeds has you in england. Try to Drive some pass with 250kmh+ and you can See how your Temperatur climbes up to 100 or more degrees.
                RS 2 580HP
                • veneto rs2
                  • Jun 2006
                  • 1022
                  • Country: Veneto
                  #38
                  Thermostat for I5T20V it's part number 069121113 period
                  It's the same part number in Nigeria Sicily Greece Canada Siberia Sahara.... Everywhere.
                  The point it's that you don't get it...
                  You seems not getting what the thermostat it's meant to do or generally why it's there
                  You don't have a clue of the basics.... how modern motor functions on regards of cooling system and/or why someone (the guy who make them!) intend to have a certain fixed temperature range on a motor.
                  This makes pointless to talk to you.
                  Quite hilarious that you were the first to talk about "brain"....
                  • K Simmonds
                    • Dec 2007
                    • 7627
                    To answer the OP's original question the Gates item is OE quality, I always use them when replacing the cam-belt on VAG cars.
                    I also can't see the point of fitting a cooler thermostat, I actually use the same 88 C unit in both my cars as I do a lot of short journeys and find it helps the them get up to operating temp slightly quicker. They both still run a notch or two below 90c once up to full temperature, the only time they ever get above 90 so that the fan activates is in prolonged slow moving traffic. My RS2 has the Aux rad fitted, my S2 doesn't, having a signal more efficient custom alloy radiator.
                    1990 B3 2.0 80 quattro.
                    1992 C4 2.8 Avant quattro
                    1994 MTM RS2.
                    1998 B5 TDI quattro Sport.
                    2000 B5 TQS.
                    • vti2
                      • Jul 2010
                      • 281
                      #40
                      Thats your opinion. I have Mine. So stay with yours and i stay with Mine.
                        So? 100 C is not an issue. 110C maybe.
                        REF:http://forums.quattroworld.com/s4s6/msgs/21881.phtml
                        • vti2
                          • Jul 2010
                          • 281
                          #42
                          I still dont want to komme so hi. Special when i make some laps on the Nürburgring... Heat will kill the Engine.
                          • Thuppu
                            • 4115
                            Yes, if you boil it.
