Trying to choose rods
  • RichLV
    • Mar 2015
    • 872
    • Country: Latvia
    Hey folks.
    I'm in the process of rebuilding my beaut, and I've chosen to stick to the safe side and get some beefier rods. I have no experience on this subject and thought maybe some of you guys could lend me a hand.
    I've got a standard daily driver power target - around 380 HP. Still haven't decided whether to opt for a 7200 or 7400, but rods are planned nonetheless. Since the power is not outrageous I'm good with an I-Beam set? Or should I get H-Beams?
    Listings which I'm looking at are following:
    http://www.ebay.com/itm/I-BEAM-Conne...item21020cd9cb
    http://www.ebay.com/itm/H-SCHAFT-PLE...item21026064f9
    Or the more expensive:
    Part number FCPRHA14450620-5FCP Engineering H-beam steel connecting rods 144mmAudi 90, Coupe - 2.3 20V (7A)200, S2, RS2, S4, S6 - 2.2 20V Turbo (3B, ABY, ADU, AAN)
    The FCP will probably be the best, but maybe it's sufficient with a little less expensive rods for my target.
    And are ACL main and rod bearings any good? Or I can go with standard Glyco/Kolbenschmidt/Mahle units?
    Anyways, please help a noob.
    I have a set of brand new SCAT rods with OEM bearings for sale
    • RichLV
      • Mar 2015
      • 872
      • Country: Latvia
      I may be interested, depends on the pricing.
        You could run that power without rods, you're not in danger level power wise, just watch the low and mid torque
        • hunker7
          • Mar 2014
          • 3487
          As Jamo said, no need for rods just get the best map available.
          '93 Audi UrS4 Avant
          '15 Audi A7 quattro 3.0 TDI
          • Rusty
            • 18953
            I went for FCP X Beam, as they're very strong and are rifle drilled, so offer superior lubrication for daily driving.
            • RichLV
              • Mar 2015
              • 872
              • Country: Latvia
              I know, but the torque is what I like and what I want the most.
              X-beams would probably be over my budget.
              • gnutz2
                • Aug 2006
                • 928
                Get the SCAT rods, cheap as chips and well within your power target, I've been running 600hp with these rods for years.
                I also had a standard (ish) 3b S2 which threw a rod out the block wrecking everything apart from the head. Obviously it wasn't the torque that bent the rods, probably detonation (some will say spark hop) and ageing knock sensors, but upgraded rods would have saved the engine.
                The ONLY S2 Golf!
                10.42@138mph
                • RichLV
                  • Mar 2015
                  • 872
                  • Country: Latvia
                  Are they available in EU? Ordering from outside EU invokes horrible taxes.
                  • popdemonic
                    • Dec 2007
                    • 1304
                    • Country: Thailand
                    Rich,the seller on those H,I Beam Rods is a good friend of mine.if you need those rods,let me know.
                    one of a few I5 from Asia.
                    • RichLV
                      • Mar 2015
                      • 872
                      • Country: Latvia
                      You mean JEMO? I bought a coil wiring set + 5coils from him. He's a good seller. But I do not know anything about those rods. It would be pita to disassemble the engine twice.
                      • popdemonic
                        • Dec 2007
                        • 1304
                        • Country: Thailand
                        Yeah,AFAIK these are not Cheap Chinese rods.he's a very good guys and he builds a big number I5 as well.
                          Then it all comes down to cost, are you balancing the bottom end? i'd go FCP like Rusty but Scat are cheap and good enough for your power level they wont balance as well as they dont seem to match the sets but this was a while ago
                          • aRtiS
                            • Nov 2008
                            • 989
                            • Country: Latvia
                            Just interest. What are high end performance rods for Audi i5 engine?
                            Audi RS2 600 hp
                            Audi S2 1200 hp
                            MB 230E '83
                            https://www.facebook.com/ventracing.lv/
                              IMO Pauter, Arrow, Carrilo
