Small Bubbles in coolant when stopped
  • Juvkam78
    • Jul 2015
    • 46
    • Country: Norway
    I have noticed that about one minute after i stop my engine hot (94 ABY) i can hear and feel small bubbles in the upper radiator hose, goes away in about 5 minutes. I have no leaks or any signs of cooling problems.. I suspect the cap on the expantion tank not sealing 100%. What do you guys think?
    Juvkam
    Nur quattro
    1994 S2 Coupe
  • Monkeymagic
    • Mar 2012
    • 3419
    Mine does the same mate it should be the after run pump pumping for a few minutes.
    • Juvkam78
      • Jul 2015
      • 46
      • Country: Norway
      This happen when the after-run pump is not running, at least i can`t hear it.. When realy hot i hear the pump well
      Nur quattro
      1994 S2 Coupe
      • Juvkam78
        • Jul 2015
        • 46
        • Country: Norway
        Problem found (I think)
        Think i found the problem today, the upper hoseclamp on the top radiator hose has cut its way through the hose, causing a tiiiny leak.. Guess a silicone hose kit is my solution
        Nur quattro
        1994 S2 Coupe
