That is bad luck that the drive failed, but it's good that you caught it before doing major damage.
I've not heard of a pump drive fail like that before. Maybe they have never been pushed that hard before, as normally cars used in serious motorsport have dry sump systems.
What grade of oil are you using, what rpm limit do you use, and what sort of pressures do you see?
