No oil pressure
  • b44jhh
    • Oct 2015
    • 45
    No oil pressure
    Hi there new to this game so please bare with me if i don't know what im talking about
    i have a audi 80 Q with a s2 engine i have just bought the car with issue with it.
    the issue is there is no oil pressure at all the car starts but make a lot of noise from bottom end i have taken the rocker cover off and it looks bone dry the car has been stood for abt 2 years there is oil in the engine but cant see it pumping round. any advise
    would be great .
    This is the car which i have bought .
  • diesel des
    • 3896
    Take off the sump and check a few bearings. Has the oil pickup tube came loose or blocked?
    Sent from my HTC Desire HD A9191 using Tapatalk 2
    • quattro-nick
      • Sep 2012
      • 1746
      • Country: Belgium
      lot of noise from bottom end and no oil pressure means i'm sure the engine is broke
      problably the crankshaft and rodbearings are gone and your crankshaft is damaged
      you can remove the sump and than the rodbearings with the engine in the car but i woud take the hole engine out and take it apart
      problably a other engine is a better solution!
      TWINCHARGED power,zero lag
      AEM W/M injection
      • b44jhh
        • Oct 2015
        • 45
        thanks guys i cant understand as it had a full engine rebuild 2 years ago and then done 2000 miles on it the sat there for two years till i started it .the trigger wheel was loose so i sorted that out put a external oil pressure gauge but no reading at all.
        • 220bhp
          • 2578
          • Home: United Kingdom
          It doesn't look good. As said it could be that a bearing has spun, Pickup is blocked or has come of. Oil pump problems. Most likely has spun a bearing. That's what happened to mine when I first bought it.
          Why has it been standing for two years. Have you checked the oil.
          • RichLV
            • Mar 2015
            • 872
            • Country: Latvia
            I feel your pain. I dodged engine damage on mine due to low pressure. Already started to rebuild.
            Do oil pumps die on 20valves? How to tell if oil pump is dying?
            • b44jhh
              • Oct 2015
              • 45
              its been standing for two because the guy went to to work abroud. so the car just sat there in the garage .
              • RichLV
                • Mar 2015
                • 872
                • Country: Latvia
                Another example of a car breaking more when not used than when used regularly.
                Drain the oil, get the sump off and remove the bearing caps. Autopsy is the only way now.
                • V6quattro
                  • Sep 2008
                  • 949
                  I also had this once on a Audi 80 which wasn't used for 1 year.
                  I think the oil pump was so dry it wasn't able to make vacuum to suck the oil out the sump. I just filled the engine oil to the level of the oil-pump and cranked the engine with the spark-plugs removed. After that i had oil pressure again Of course you need to drain the excess oil after that.
                  1360kg/600Whp Avant 0-200km/h 9sec
                  • K Simmonds
                    • Dec 2007
                    • 7627
                    That's an interesting car, I used to follow the thread written by the guy who did the RWD conversion, has it still got the big Garret turbo?
                    How long has it been run with no oil pressure? Any longer than a few seconds will normally cause damage to the main bearings and as has been mentioned it may have spun one.
                    In any case I'd remove the sump and see what's going on...
                    1990 B3 2.0 80 quattro.
                    1992 C4 2.8 Avant quattro
                    1994 MTM RS2.
                    1998 B5 TDI quattro Sport.
                    2000 B5 TQS.
                    • steve briance
                      • Aug 2014
                      • 1455
                      connecting rod bolts are a false economy not to replace.
                      I once rebuilt an engine for a kit car re using the con rod bolts on the advice of an engine repair shop who told me they wern't stretch bolts...
                      They were stretch bolts and within a very short period of time the big end was banging and clattering and a piston presented itself through the side of the block on my way to my mates garage to strip it down and check what was going on
                      as already mentioned; you've got to drop the sump and have a look - you may even find that the bolts have come undone...
                      • b44jhh
                        • Oct 2015
                        • 45
                        Its still the same as dunstan left it untouched this is why im having this problem .like you guys mentioned sump off etc..
                        • simon20vq
                          • Dec 2010
                          • 1379
                          Just looked at some of the pic's....very nice!
                          • SteveH
                            • 4460
                            I'd put my money on the dry oil pump. Without oil they can't make vacuum to pickup oil from the sump. Unfortunately it sounds too late now. You can remove the oil senders and use a syringe to inject some oil into the passages. I've managed to get a dry pump working through priming it with this method.
                            91 Modded 3B
                            14 A6 Avant Black Edition
                              IMHO that was a nasty ghetto build that ruined a perfectly good car, so I'm not surprised its got issues. Personally I would start from scratch and rebuild the car properly
