*HELP* A6 2.5 TDi Failed Fuel pump!
  • Biggss2
    • Sep 2011
    • 544
    Hello All
    My 2005 Allroad has decided to pack up on me.
    I would be lying if i said I knew it wasnt coming, but it used to take ages to start first thing, sometimes 20-25 seconds on the starter irrelevant of how many times I put the glow plug light on and off. Changed Coolant sensor as it was cheap made no difference!
    NOW- the car wont start, not for love nor money.
    Reading about it, the ECU on the VP44 pump is a common failure, and mine looks to have failed.
    Part number 0281010889
    rang a few people, they said they cant repair! (ATP, ECU technologies, blue streak)
    Any suggestions/ Anyone know of someone who can repair?
    Thanks Biggs
    ''I'm 999 thou' short of a mill!''
  • simon20vq
    • Dec 2010
    • 1379
    I thought it was the ECU on the top that failed? Have you tried 'diesel bob' on line? Also have you checked the diesel pump belt for timing?
    • Biggss2
      • Sep 2011
      • 544
      Hi
      It is the ecu I believe has failed ive removed the ecu pump still there as before
      I can see marks on the casing where previously it has been tapped with a hammer or similar to get it going again
      • simon20vq
        • Dec 2010
        • 1379
        Ebay?
        • Biggss2
          • Sep 2011
          • 544
          Coded to the immob so it's best to repair current ECU. I wish it was as simple as putting another one on!
