safety installation on water/methanol injection
  • quattro-nick
    • Sep 2012
    • 1746
    • Country: Belgium
    so i building a water/methanol injection from AEM in my car and i want to make a boost protection when the w/m system fails
    the little w/m ecu has a wire that becomes a ground when the reservoir is empty or if there is an error
    How do I obtain a low boost pressure
    maybe if I interrupt the wire from n75 valve? (with a relay)
    i have a tial waste gate (44mm) and dont know how many boost the waste gate spring will give
    i use vems but have all the external terminals already in use
    thanks in advance!
    nick
    TWINCHARGED power,zero lag
    AEM W/M injection
  • quattro-nick
    • Sep 2012
    • 1746
    • Country: Belgium
    okay,i've read that when the n75 valve is disconnected you only have waste gate spring boost pressure
    AEM W/M injection
      MFTS will cut boost on an over temp signal (pulls to earth)
      • martinws
        • Oct 2008
        • 917
        That is on motronic though, this chap is running vems. Cutting n75 with relay would work as well. What have you got on the other inputs?
        • quattro-nick
          • Sep 2012
          • 1746
          • Country: Belgium
          launch control and 2 outputs for clutch and bypass valve for my new twincharged project
          AEM W/M injection
          • Thuppu
            • 4115
            DANG!!!
            • quattro-nick
              • Sep 2012
              • 1746
              • Country: Belgium
              3 november dyno day whoop whoop
              AEM W/M injection
