fuel injector recommendations
  • orignalS60
    • Mar 2015
    • 792
    • Home: Croatia Current: United States
    What do you guys recommend or have used
    for injectors on your builds? I'm running a
    gtx3582r on E85. I have a rebuilt AAN with
    rods. Do you think 1,200cc would be sufficient
    or should I go bigger?
  • jsol
    • Jul 2011
    • 353
    • Country: Australia
    I'd be looking more toward 2000cc.
    • V6quattro
      • Sep 2008
      • 949
      Go bigger. I have 1200cc@3bar and running them on 4 bar and they are maxed out.
      1360kg/600Whp Avant 0-200km/h 9sec
      • Tille
        • Feb 2014
        • 41
        1700cc @ 3bar
        Audi Coupe Typ89 10V Turbo - VEMS - Billet K26 - Deka 630 - E85 - 3" Exhaust
        • orignalS60
          • Mar 2015
          • 792
          ^^^Perfect, thank you.
          • Thuppu
            • 4115
            EV14 0 280 158 827 (1700cc)has bad reputation with e85. The flow characteristics change when the internal seals swoll.
            EV14 0 280 158 821(2000-2200cc) has been proven to work very well with e85.
            Both these are gas injectors, so Bosch wouldn't quarantee that they work with fuels. If you wan't to be 100% sure about e85 compatibility then buy these: http://www.finjector.com/verkkokaupp...-p-519967-188/
            • blackS2
              • Apr 2010
              • 455
              1700 CNG injectors have also known issues with gasoline at higher fuel temperature because flow characteristics change...
              [__]=oooo=[__]
              • Thuppu
                • 4115
                Yes, exactly.
                I'm running these with e85 atm. http://www.finjector.com/verkkokaupp...-p-125606-188/ But the idle is worse than with 1200cc EV14. Other wise no issues.
                • orignalS60
                  • Mar 2015
                  • 792
                  Thomas those bosch 2,200cc injectors use
                  ev14 connectors correct. Just to clarify
                  the stock AAN injectors are ev1 so I
                  would need adapters. Also these are very
                  short so I'm guessing I would need a 60mm
                  height spacer?
                  • Tille
                    • Feb 2014
                    • 41
                    Don't know where these romur comes from...
                    When the gasoline becomes hot the thickness of the gasoline change. (dont know if thickness is the right word, in german it's "dichte") The injector flow is the same. 30°C higher gastemp means 4% less thickness. Thats why lambda gets thinner @ high gasoline temp. The higher the cc of the injectors, the more lambda get thin.
                    Tuned 5 cars with the 1700CNG injectors on E85 and Ultimate102. No problems yet.
                    4x 2xPierburg fuelpump@3bar. +10-16° fueltemp, no lambda difference.
                    1x 2x044 Bosch @4bar. +33° fueltemp, corrected VE via FlexFuel+Anytrim.
                    1x 2x044 Bosch @4bar 2200 ID's. +25° fueltemp, corrected VE via FlexFuel+Anytrim. Without correction lambda went from 0.78 cold to 0.85 high gastemp. The biggest difference i ever measured.
                    The same procedure is used in every TFSI and CR Motor.
                    Greetings from Germany
                    • Audi_CQ
                      • 940
                      • Country: Norway
                      How much power? Maxed out as in 90-95%?
                      • orignalS60
                        • Mar 2015
                        • 792
                        His sig says 600whp.
                        • V6quattro
                          • Sep 2008
                          • 949
                          Around 95% yes.
                          • orignalS60
                            • Mar 2015
                            • 792
                            Does anyone know if those 2,200cc
                            injectors need adapters for an AAN
                            harness and spacer hats for the rail?
                            • Thuppu
                              • 4115
                              Well, they are O-O 34mm and you would need O-O 61mm so the answer to your question is, yes you would need spacers. And you would also need adapters for the electric connectors.
