Coil issue? Sporadic ignition cut
  • happykriss
    • Mar 2013
    • 60
    • Country: Norway
    Hi everyone!
    I have an AAN powered S2 coupe that recently started playing with me.
    I upgraded to TFSI coils recently and a day or two later it started cutting ignition.
    You can drive for a while then it just dies a second. I have noticed the RPM needle have dropped a couple of times, but i thought at the beginning it was a failure in the instrument. Still not sure if this is connected with my issue.
    I've replaced both sensor at crank without any improvement.
    I pulled an extra ground to the coil for safety, but no difference.
    Only error i got is:
    Engine speed sensor (G28) Sporadic- implausible signal
    This is NOT the standard "Engine not running" fault code (Correct me if i'm wrong) so i'm starting to believe there is a interference with the signal due to coil pack.
    This is my one and only car at the moment so all help is really appreciated.
  • mike74
    • Apr 2014
    • 615
    Ignition switch playing up?
    • happykriss
      • Mar 2013
      • 60
      • Country: Norway
      Maybe. I tried wiggling the key a little while driving but no difference. Not sure if that would be considered a good way to test it though. Think i need to check my groundings.
      • RichLV
        • Mar 2015
        • 872
        • Country: Latvia
        What spark plugs do you run? Had the same issue when swapping to TFSI coils. Turns out my 3 month old F5DP0R's started misfiring, but it wasn't a light misfire, it was like a complete cut across all cylinders. And because of the violent car shaking that happened during misfires I got all kinds of mystical fault codes - G40 bad, G4 bad, G28 bad etc. Swapped the plugs and it all went away like never happened.
        • happykriss
          • Mar 2013
          • 60
          • Country: Norway
          Hi, thank you. I believe i used F5DP0R but not sure.
          May i ask what you swapped them with?
          • RichLV
            • Mar 2015
            • 872
            • Country: Latvia
            Just to test I swapped my old NGK PFR7Q plugs in. Car started to go like a charm. Right now I'm rocking NGK BCPR7ET.
            • happykriss
              • Mar 2013
              • 60
              • Country: Norway
              Thank you for your input. I will try some other plugs tonight.
              • RichLV
                • Mar 2015
                • 872
                • Country: Latvia
                Keep a spare coil in the glove box. Because of incorrect dwell timing, these can die fast.
                • happykriss
                  • Mar 2013
                  • 60
                  • Country: Norway
                  I will do that. They have been on my VEMS powered S4 engine and worked well there for the last 10 000km. Is it Bosch ECU that kills it?
                  • RichLV
                    • Mar 2015
                    • 872
                    • Country: Latvia
                    Yep, too much dwell time on Motronic, they tend to overheat. Don't cover them.
                    • happykriss
                      • Mar 2013
                      • 60
                      • Country: Norway
                      I swapped the plugs for some Denso IU22 today as we got them at work for a good price.
                      Can anyone tell me why the old are brown? Boost leakage or heat that make them look like this?
                      • RichLV
                        • Mar 2015
                        • 872
                        • Country: Latvia
                        Dunno about the insulation but by the looks of the tips you're running rich. All black and sooted.
                        • happykriss
                          • Mar 2013
                          • 60
                          • Country: Norway
                          Going to install af gauge soon. Know its a little to rich, but not sure what to do about it.
                          Sent fra min SM-N910F via Tapatalk
                          • RichLV
                            • Mar 2015
                            • 872
                            • Country: Latvia
                            Most likely an air/vacuum leak after MAF. PCV system check would be the first I'd check. I had problems with the Check Valve hose, it was hand made from 2 hoses.
                            • mike74
                              • Apr 2014
                              • 615
                              ^^^ agree. You've probably got the infamous 00561 mixture adaptation code too
                              Boost leak test time!
