Crank
  • b44jhh
    • Oct 2015
    • 45
    Crank
    Hi there need a bit of info is 7a crank same as AbY and 3b
  • RichLV
    • Mar 2015
    • 872
    • Country: Latvia
    All 5 pot petrol cranks are the same - 034105101S.
    • b44jhh
      • Oct 2015
      • 45
      Cool
      • bn-01-wso
        • May 2009
        • 471
        • Country: Romania
        Not quite all of them. For example MC 10VT has a smaller diameter of the rod journal. But the 20v i think they are all the same.
          I don't know if that as originally true or not. But now, the only 20V (7A, 3B , AAN,ABY and ADU crank) is as suggested= 034105101S. 034105101S is also listed for the KV and NG. The NM with it's smaller displacement used a shorter throw crank, a 034105021G which was used in some 2L 10 V engines as well.
          • SteveH
            • 4460
            From way back I seem to remember some cranks are forged and some are cast. There was a post about it from Mark H
            91 Modded 3B
            14 A6 Avant Black Edition
            • V6quattro
              • Sep 2008
              • 949
              Yes i'm running a cast crank in my car.
              1360kg/600Whp Avant 0-200km/h 9sec
              • RichLV
                • Mar 2015
                • 872
                • Country: Latvia
                AAR also. I wasn't sure about pre-1990 cars.
                • igor136
                  • Jun 2014
                  • 363
                  • Country: Croatia
                  Look at this . The man says that the difference in the oil channel.
                  1-2-4-5-3
