quick oil pressure question
  • george21
    • Aug 2007
    • 226
    • Home: Lithuania Current: United Kingdom
    Just wanted to ask regarding oil pressure on my aby engine.
    When it's cold I got 5 bar pressure
    When it's hot I have 1.2-1.3 bar on idle
    When revs up to 2500-3000 rpm I got 3 bar pressure on hot engine
    The question is: Oil pressure won't go past 3bar on hot engine no matter if it's 4000rpm or 6500 rpm, it just won't go past 3 bar. Is that normal? If no, what does it mean?
    Oil 10x40
    Thank you guys!
  • Thuppu
    • 4115
    Try to shimm the oilpump pressure relief valve spring.
    • Rikki Kitto
      • Feb 2010
      • 6276
      What is it when driving in high revs, should be 4/5.
      1.2/3 at idle on warm engine is normal
      • george21
        • Aug 2007
        • 226
        Whatever revs are it wont go up more ten 3bar
          What weight oil are you running? 3 Bar is too low.
          • RichLV
            • Mar 2015
            • 872
            • Country: Latvia
            Had 0.8 at idle on mine. Hot engine barely 2 bar at 2000 rpm. Turned out to be a bearing fault.
            • Michael S2
              • Dec 2011
              • 1378
              Cold engine 5 bar at idle.
              Warm engine at idle 1.5 - 2 bar
              Warm engine when revving 4 - 5 bar
              10w50 oil
              1995 Audi S2 Avant
                10w50 oil
                This is what I have with 20W50 in the summer. I think it is normal. Less than 2 Bar on hot idle would concern me.
                • george21
                  • Aug 2007
                  • 226
                  I'm using 10x40 oil. So what are you guys thinking? Is that mean main bearing on the way out or worn oil pump.
                  If it is oil pump then, as thuppu suggested shimming should help, but for how long?
                  Is it anything else that can course that?
                  • Michael S2
                    • Dec 2011
                    • 1378
                    Checked mine again at warm idle and the needle sits just a little under 2 bar so about 1.8 bar. My old s2 coupe with half the miles was the same so i am happy it is fine
                    1995 Audi S2 Avant
                    • s2driveruk
                      • 12696
                      5w50 oil and 4-5bar above 1500rpm and normal driving, 1.8-2bar at idle on warm engine. When ambient temperature is high or after a lot of fast driving then hot idle can be slightly lower say 1.5-1.7bar.
                      20-50 seems really thick oil?
                      1992 3b S2 Coupe
                      • varia
                        • 821
                        • Current: United States
                        all the way down to as low as 1 bar at idle (hot) is ok.
                        • george21
                          • Aug 2007
                          • 226
                          so what is correct pressure should be, by audi manual ? how many shims I can add?
                          • Zoig
                            • Sep 2008
                            • 555
                            Are you sure shimming is the correct solution? I just helped a rebuild on 1989 220v, all bearings remained original '88 with the tolerances in factory spec. Looser end of the spec, but still within spec. The car had 1.5Bar on hot idle measured on mechanical gauge as the interior gauge shows around 0.5-0.8bar less, and 5+bar on revs (5W40 oil). After the rebuild the interior gauge is between 1.8-2.0 on hot idle (approx 2.5Bar in real world). The oil pressure loss was actually because of the leaks between pressure side on the pump and block and also the oil pickup was loose.
                            Instead of shimming it i would measure the rod bearings for wear and make sure there are no internal oil pressure leaks that are not obvious. Without finding out the cause and just applying remedy you are only fooling yourself, fix it.
                              According to which Audi technical service bulletin? Too low IMO.
