Hi Gents and Ladies,
Please see my list of Upgrades and Sequence of installation.
Please add in comments if you disagree with the sequence or things I need to add in.
I have all the parts for the upgrade, I have purchased everything and all I have to do now is fit them.
1 Install RS2 intercooler.
2 Dyno the car stock, see performance is equal to standard RS2. If the performance is equal to a standard S2 then proceed to step 3 if not take to Audi, Audi to do a complete service oil change etc and locate issues causing performance issue. Return to start of step 2 until Audi have corrected any issue that prevent the car from performing to that of a standard ABY S2.
3 Install Upgraded coil conversion kit and R8 Coil packs.
4 Test car for a while.
5 Install larger pump basket and new Bosch 440 pump. (Wiring mod will be done)
6 Fit new Bosch 440cc injectors.
7 Install replacement upgraded ECU complete with 4 bar sensor upgrade.
8 Test car is running ok
Advice needed. Is it ok to run as it is only points 1 – 6 completed. RS2 Turbo and inlet manifold not yet installed.
9 Install RS2 Turbo and manifold.
10 Test run.
11 Take car in for DP and exhaust upgrade.
12 Test run.
13 If all ok return the car to the original place that did the first dyno test. Compare to stock.
14 If car gets 360-380hp and runs well mods have finished go and enjoy myself
orsum
10 Test run.
12 Test run.
orsum
I did mine recently and the usual things pop up when increasing power. Weak coils, boost leaks, spark plugs failing, then all the other additional things that more power affects like drive system bearings bushes ball joints etc
Although I have got performance brakes and suspension should I ever get round to some power upgrades!
