BorgWarner EFR or Holset?
  • rxl
    • 1913
    amloast all the rods are made in china and they are in good quality. if your on the budget buy one and try. some of them hold for a long time
    • diesel des
      • 3896
      #32
      It's very unlikely that when a turbo dies it kills the engine. It's not impossible, but it's unlikely. If the turbo fails, the turbine wheel can go out the exhaust. This isn't a problem. The compressor can burst, but the intercooler catches all the big pieces, and very little reaches the intake and what does is small enough not to cause lots of damage. The oil bearing system can fail and put lots of oil into the intake or exhaust, but blue smoke gives that away, as does oil pressure.
      This is my experience at least. It's worse on a diesel as the oil can fuel the engine and it revs hard. But in a petrol engine it's usually not very spectacular, and there is a grinding noise and some smoke.
      Sent from my Moto G (5) using Tapatalk
      • Airwolf
        • Jun 2017
        • 79
        • Country: Norway
        #33
        EFR 7670 on mtm sq exhaust manifold and t3 housing.
        Sent fra min SM-G935F via Tapatalk
        • Tom_
          • Oct 2007
          • 1301
          • Country: Czech Republic
          #34
          Looks good, but the price tho If i know that spool and power peak with that chinese ball bearing will be good, i buy this
          Audi Coupe Quattro 2.3 20V
