AAN, 3B and ABY, ADU wastegate difference?
  • hajbed
    • Jul 2006
    • 146
    • Country: France
    Hi,
    the part number of AAN/3B and ABY/ADU wastegate are differents.
    Anyone know why?
    3B/AAN : 034 145 705 B
    ABY/RS2 : 034 145 705 E
    Is this because of a different spring or is there any other reason?
    Thank for your help
  • s2coupe3b
    • Sep 2015
    • 10
    adjusting screw in the wastegate cap screwed a little deeper for more spring preload.
    • hajbed
      • Jul 2006
      • 146
      • Country: France
      Had you the two models on your hand to can compare it?
      Thanks.
      • s2coupe3b
        • Sep 2015
        • 10
        Hi,
        I no longer have the possibility to measure it exactly, the adjusting screw from the ABY it just screwed a little deeper in the wastegate cap than on the 3B.
        maybe someone measured it here?
