I found this site quite useful when sorting out a couple of RR's that had similar issues to yours.
Boost issues with ur quattro rr engine still!!
Fuel lines are all new and it's running a Bosch 044 with new filter so i doubt it's that.
I will put timing on my list.
Maf was brand new and cost me £360! But I'll check pins in the connections and the wiring.
The car didn't put me through the windscreen, it will Rev and boost then struggle high up the Rev range and there after the car wont pull as hard until I turn the ignition of and on againComment
Hard to tell without pulling the codes but that does sound like a knock sensor. As previously suggested, replace both.Fuel lines are all new and it's running a Bosch 044 with new filter so i doubt it's that.
I would imagine that they are in quite poor condition.Comment
Deos it feel like the revs are climbing then then like a slight pause n carry on?'83 URQ - Full 20V Conversion - Pearl White
'85 URQ - 20V Conversion - White
'88 URQ - Nile Green - SOLD
'95 RS2 - Ragussa Green
'95 S2/RS2 Coupe - Blue
'00 B5 RS4 - White - SOLD
'01 B5 RS4 - BlackComment
