antifreeze question?
  • MGaz
    • Feb 2008
    • 698
    What type of antifreeze are you guys running in your i5's?
    I've always flushed mine, and used the pink/red stuff with distilled water and a 50/50 mix.
    I just wanted to check if ive been doing the right thing?
    I have pink in my KV quattro and pink i my AEL C4 A6..
    C4 A6 AEL avant quattro: daily
    TYPE-85 Coupe Quattro: clicky
    2.5L GTi engineering RE2500 190hp.180lb
    Schrick 272 cam
    C A C 2.5" T304 Exhaust
    ITG filter
    OEM G12+/G13. Put about 4L in and top off with distilled water.
    • quattro turbo 550bhp
      • Nov 2009
      • 416
      • Home: Pakistan Current: United Kingdom
      antifreeze
      distilld water why iv always used norm tap water is that wrong
        Don't think so, I've always used it as our water is really hard so avoids the mineral deposits
        • MGaz
          • Feb 2008
          • 698
          So... is OAT basically what G12 is?
          Also, I've just been reading that OAT is bad for copper radiators and heater matrix's? And is no good for lead soldered rads either?
          Does my kv quattro, or even my c4 AEL A6 have any copper in the cooling system? Or lead solder?
          Hummm... the more i look into this, the more un sure i become. :-\
          Schrick 272 cam
          ITG filter
