i run with a precision 6262 like V6quattro, size is similar to GT/X 35. i have 2.0Bar with 1000cc injectors on 4bar fp. this year up to 2.5bar.
but Nick be careful with the Arlows Rods!!! i have seen these rods and some damadged engines. these are cheap china parts, the quality isn't good. rod-weight have big tolerance in some sets. i wouldn't run these rods in my engine with such a big turbo.
max boost on my engine with a gt3582r
injector size is roughly hp on the 5 pot. so mid 600's
I ran 2 bar on my sc61 which is similar to a gt35 turbo. stock skimmed pistons. no issues.
I have same pump and same injectors as you. I run the 4bar reg aby. I had a bit more in it I think.
I feel this is where cams, headflow come into it. is the boost at the inlet or the chamber? can we get more air in more efficiently thus meaning less boost for given hp. or more hp for given boost.Leave a comment:
Hy Nick! Im running 2.4 bar on a gt35 size turbo.
And i think is beter to get bigger injectors like 1200cc ev14. And if you plan running e85 i would go even bigger. I have 1200cc@3.6 bar maxed out on e85Leave a comment:
my engine have arlows rods and wossner pistons good for 800hp strength and my compression ratio is 8.0/1 so i wonder what is the max safe boost with my future gt35 turbo on the engine
in the past i've driven with a gt3076r on 2.0 bar boost
i've seen a s2 thread on the net with this turbo and he drive with 2.5 bar boost
i presume that this wil be safe when the intake temp -watertemp-exhaust temp and oil temp is in the limit on max load
also about the fuel,i have a single bosch 044 pump,siemens deka 630cc injectors and a fuel pressure regulator
woud this be enough to accomplish 600-650hp? or need i 850cc injectors
what is the max hp with 630cc injectors? i can put 4 bar pressure on the fuel rail
thanks
nickLast edited by quattro-nick; 24 February 2016, 11:49.Tags: None
