Audi urq with aby engine. Which silicone hoses
  • diesel des
    • 3896
    So does an S2 silicone hose water kit for a urq a a 20vt? Im thinking of the heater matrix hoses too? Or is it all custom?
  • quattro-nick
    • Sep 2012
    • 1746
    • Country: Belgium
    Des,can you not order a silicone kit for a ur 20vt RR ?
    TWINCHARGED power,zero lag
    AEM W/M injection
    • diesel des
      • 3896
      Can't seem to find a rr kit...
      • diesel des
        • 3896
        These seem to be the closest.
        Stainless Steel Clamp Kit To Fit: Hose kit 244s (Porsche 996 Turbo, Turbo S and GT2 DO88 Y-Hose) The kit contains all necessary hose clamps to install the
        But they are for non UK cars of that's important and also don't include the heater matrix hoses.
        • quattro-nick
          • Sep 2012
          • 1746
          • Country: Belgium
          are you still gonna use the little aux radiator in the front?
          AEM W/M injection
          • diesel des
            • 3896
            Nope I have a 74mm main rad.
            • quattro-nick
              • Sep 2012
              • 1746
              • Country: Belgium
              the link sells radiatorhoses with aux radiator but you can make it shorter with a plug maybe
              or you can make custom tubes
              for the bottom radiator hose you can use a hose from a b2 coupe with the 10vt thermostat house
              AEM W/M injection
              • diesel des
                • 3896
                Cool. How does a s2 compare? Where is heater matrix in an S2?
                • quattro-nick
                  • Sep 2012
                  • 1746
                  • Country: Belgium
                  what typ of water manifold and intake are you going to use des ?
                  AEM W/M injection
                  • diesel des
                    • 3896
                    I have an aan and an aby water manifold. I have cut and modified aan intake that's now front intake. Just not sure what I need.
                    • kibby
                      • Sep 2009
                      • 165
                      Water hoses
                      Hi des the s2 matrix hoses are bigger I used redusers to plumb aby hoses to matrix
                      • quattro-nick
                        • Sep 2012
                        • 1746
                        • Country: Belgium
                        des,i did the same thing so i know that the aby water manifold wont fit with aan intake!!
                        i use the aan water manifold
                        i have cut the front connection and weld it back on more backwards almost on the same place as aby manifold(sie picture)
                        for the matrix,i placed on the back of the engine block the origional metal connection from my old kv engine so that tube is back a straight fit,the other one have a made custom with the watervalve(hot/cold) in it
                        AEM W/M injection
