Won't start
  • ped
    • Dec 2015
    • 42
    Won't start
    Pretty typical, was meant to take the car to the garage today for it's MOT on Weds. Completely dead when I tried to unlock so used the key. Nothing happened when I put the key in, no immobiliser light flashing (TOAD system) nothing.
    Connected a digital jump pack for 10 mins plus and now the remote locking works and immobiliser OK. Batt voltage on dash showing 12v.
    Key in - light come on, looks good... one more turn... a hoarse cough as the engine tries to turn over but doesn't manage it.
    Car has been sitting for about a week but has usually been OK.
    Do I have to call the AA on Monday?
  • hermanio
    • Jan 2009
    • 800
    Replace battery
    5 Cylinder Freak
    • ped
      • Dec 2015
      • 42
      Thanks, that's a possibility I suppose but I don't think the one in there is very old. I may be wrong.
      Can any UK members recommend a vendor to get said battery, Halfords seems to come up with a blank when I enter the reg.
      • RichLV
        • Mar 2015
        • 872
        • Country: Latvia
        If it doesn't turn over then either the starter or the battery. I'm running Deta Senator batt's in my Audis.
        • ped
          • Dec 2015
          • 42
          Thanks it does turn over slowly but just not fast enough!
          • ped
            • Dec 2015
            • 42
            Current batt is 12 months old so should be OK.
            • ped
              • Dec 2015
              • 42
              Left with boost pack connected for 30 mins, no success.
              • John.
                • 2615
                What's the CCA rating of the booster pack compared with the rating on the battery?!
                • ped
                  • Dec 2015
                  • 42
                  Pack is 500 amps. Same as battery (Quantum 096)
                  • SteveH
                    • 4460
                    Put it on charge overnight, that will rule out insufficent charge. If the battery is still low on power, take it back as they all come with a guarantee, most 2-3 years. Euro Car Parts is cheap enough for a battery. I would go for Bosch Silver, Varta or something of decent quality.
                    91 Modded 3B
                    14 A6 Avant Black Edition
                    • ped
                      • Dec 2015
                      • 42
                      I don't have a car battery charger so might see what the AA say as I have home start...
                      • Dynasty
                        • Jan 2015
                        • 79
                        • Country: Norway
                        Alternative 1. Use jumper cables
                        Alternative 2. Push start the car
                        Alternative 3. Give the battery a proper charge
                        • John.
                          • 2615
                          ...... see what the AA say as I have home start...
                          Any news?
                          • chez
                            • Feb 2005
                            • 49
                            Battery knackered.
                            Age of the battery doesn't matter if your
                            Not using the car regular .
                            There not designed to sit for weeks without
                            Some sort of charge
                            • Monkeymagic
                              • Mar 2012
                              • 3419
                              Agree with the above, sounds like the battery has eaten itself buy a battery trickle charger to maintain it. My car doesn't move over the winter battery is still good. ( watch it pack up now!!)
